Technical Forum
Problems with Portal Access rewrite APM
Eric_Holo
Hello,
I am having issue with the portal access apps, I cannot access to the web page because some elements were not rewritten.
What Irule can I use to make it correctly changed.
When I do F12 on a browser, the request URL, there is missing the variable f5-w-<webpageHEXADECIMAL>) leading the a missing
2 REPLIES 2
Could you share some screens of your APM configuration?
boneyard
MVP
MVP
personal experience is to engage F5 support on this, they have a couple of quick things to try and can guide you better on your configuration and website behind it.
