prevent F5 APM from adding Fetch Metadata Request Headers
synflood
F5 APM Portal Access is inserting the following headers into requests sent to the internal web app, and it's breaking the app. Is there any way to disable, or remove with an iRule?
Sec-Fetch-Dest: document\r\n
Sec-Fetch-Site: same-origin\r\n
Sec-Fetch-Mode: navigate\r\n
Sec-Fetch-User: ?1\r\n
0 REPLIES 0
