Persistence via iRule not working
Hello
I am somewhat new to iRules, but have a general understanding how it should work.
I have a virtual server for a proxy service with a pool of 4 IP addresses without any default persistence set.
What I want is that when I specify a URI parameter (query string) when I request any URL is to be set to use a specific backend IP for ALL the traffic for the next say 5 min or until I close the browser. So that I can request https://www.google.com?useProxy=proxy1 and iRule will send all the traffic via just this proxy, regardless if I continue to use the parameter or not.
At the moment it only works on the initial request, but it does not set persistence for URLs that do not contain a proxy parameter in the URL...
Can someone help?
I cannot user source_addr persistence as there is another F5 before that, so that source IP will always be the same...
if { ([HTTP::uri] contains "useGRE=MO") || (([HTTP::header exists "Referer"]) and ([HTTP::header value Referer] contains "useGRE=MO"))} {
persist dest_addr 255.0.0.0 180
node 1.2.1.1 80
} elseif { ([HTTP::uri] contains "useGRE=MT") || (([HTTP::header exists "Referer"]) and ([HTTP::header value Referer] contains "useGRE=MT"))} {
node 1.2.1.2 80
} elseif { ([HTTP::uri] contains "useGRE=SO") || (([HTTP::header exists "Referer"]) and ([HTTP::header value Referer] contains "useGRE=SO"))} {
node 1.2.1.3 80
} elseif { ([HTTP::uri] contains "useGRE=ST") || (([HTTP::header exists "Referer"]) and ([HTTP::header value Referer] contains "useGRE=ST"))} {
node 1.2.1.4 80
