15-Jun-2020 09:14
Hi devcentral,
Is there a way to manipulate timeout timespam a persistence record?
We have a timeout of many hours that we want to reset to 1 hour for a disable pool member.
Devcentral you can do it 🙂
Solved! Go to Solution.
16-Jun-2020 09:05
Hi CDG,
I get the feeling that only suppression is possible.
REF- https://support.f5.com/csp/article/K55632517
Regards
16-Jun-2020 09:05
Hi CDG,
Regards
