sarat_82132
Jun 01, 2015Persist Variables Between multiple Irules
Hello :
I have a quick question. I want to set a value to one variable in one Irule ( HTTP_REQUEST) and retreive the value in another Irule. I could not figure out a way for this. the only option that comes to my mind is using request header.
- nathe
Cirrocumulus
Sarat,
You can create a global variable, based on something, and then call this in another irule. Take care, however, and ensure it's a static global variable. See the following for more details irules-101-variables
Hope this helps,
N
