davejp_196352's avatar
davejp_196352
Sep 29, 2016
PeopleSoft HTTPS connection immediate connection expired after login screen
I'm using LTM version 11.5.1 and setting up access to PeopleSoft 9.2 for a migration. I have HTTP working fine using iApps and when I set it up for using secure connection I can get to the PeopleSoft login screen, put in credentials and then will immediately get a screen "your peoplesoft connection has expired". I have verified that session persistence is cookie and have used the default setup and also modified it with a new cookie name. This was to verify via Wireshark that the cookies were being passed. I have reviewed the configuration and system setup and have not found anything that sticks out as not being configured correctly. Is there something missing from the F5 setup or is it possibly a server issue?
