15-Mar-2023 09:56
Hi All,
What default parameters are there in monitor /Common/https.
Wanted to know client request header value, server response code if any, send interval, receive interval, success check, failure checks and etc.
Solved! Go to Solution.
15-Mar-2023 10:57
@Aditya_Kurundka This should easily be visible by going to the health monitors and clicking on the one labled https. The following article has what you are looking for and should be able to search for "HTTPS monitor settings" to find the specific spot in question.
16-Mar-2023 00:12 - edited 16-Mar-2023 00:44
15-Mar-2023 10:57
you can also use these:
https://my.f5.com/manage/s/article/K13522220
https://my.f5.com/manage/s/article/K81239024
16-Mar-2023 07:58
Thank you
