Technical Forum
Other Memory Utilization is more than 95%
lttarvina
Altostratus
Altostratus
The memory utilization of vCMP hosts at 90 percent and above are expected because vCMP hosts allocate all their CPU cores to their vCMP guests. This design reflects the vCMP hosts as being fully utilized.
The questions is, is it normal to have an above 90% utilization for other memory if it is not a VCMP Host?
How can we explain to non-technical staff that 90% and above utilization for other memory is normal?
1 REPLY 1
boneyard
MVP
MVP
where do you see this high usage? because it is normal for some tools to show it as high, but that is mainly reserved not an issue
see also: https://support.f5.com/csp/article/K16419 and https://support.f5.com/csp/article/K52090030
