Technical Forum
operation specialist
Prachiti
I have 2* 700As Netapps which is 40G bandwidth they need connection from nexus 5k switch.
I have only 10g ports available in the switch so I try to bundle 4*10G ports to give 40G throughput.
Will it be possible to bundle 4 ports 0f 10G to support 40G interface BW?
How to configure those ports ?
1 REPLY 1
Hi, you can configure LACP PortChannel on Nexus and F5
http://itadminguide.com/connect-f5-to-cisco-switch-on-ether-channel/
