Technical Forum
old configurations
suthomas1
Good day all,
Is there a quick way to check on what virtual servers, objects, certs, policies may not be in use.
if so we want to find a way to remove unwanted configs.
thanks in advance.
1 ACCEPTED SOLUTION
Samir
MVP
MVP
Quickly generate the qkview and upload on ihealth.f5.com and see the magic.
1 REPLY 1
Samir
MVP
MVP
