Odd Connection resets returned by
Hello,
We have followed the design guide to deploy exchange behind our edge gateways and ltms.
Couple of facts about our environment
LTMS 3600s running BIG-IP 11.1.0 Build 2027.0 Hotfix HF2
Edge Gateways 1600s running BIG-IP 11.2.0 Build 2713.0 Hotfix HF3
Nothing is Natted(CAS nodes see real ips)
It is deployed exactly as specified by the design guide.
Basically what is happening at random. When a user logs in via the Edge gateway to owa, randomly the ltm will return a rst. Upon refreshing the browser traffic flows as normal.
I have confirmed that the reset is being returned from the ltm, as I followed the traffic back doing packet captures. Comparing the packet captures from a regular request and a request that recieves the reset, they appear to exactly the same request.
Is there anything else that I should look at? I asked here, because I dont necessarily believe it is directly related to the Exchange iApp or Design guide, just wondering what else could cause resets to be randomly returned.
I know this post lacks a lot of information, I just wasnt sure what information to provide, or the type of response I would get.
