Technical Forum
Custom Alert Banner
OCSP stapling is not working- V14.1.4
newbeeocsp
Altostratus
Altostratus
Hello Expert,
Need your assistant with troubleshooting OCSP stapling . I am using LTM with version 14.1.4 and getting below error.
"OCSP Connection Error: HTTP response doesn't indicate that it is an OCSP response."
I am using dns reslover to implement OCSP stapling. In one of fourm it was mentioned about change status age to 7 days but it did not fix the issue.
Any help would be appreciated
Thank you
3 REPLIES 3
Kevin632
I had OCSP must staple was not selected when certificate was issued . Now that is fixed and applied reissued certificate but issue still persist. In ssllab test I am getting this now :
This server certificate supports OCSP must staple but OCSP response is not stapled
OCSP Must Staple:Supported, OCSP response not stapled
also I have in OCSP profile Request signing certificate option as none .
