Technical Forum
NTLM authentication in APM
a_basharat_2591
I have the following APM Policy defined on a Virtual Server:
To introduce NTLM on it [following the article: https://devcentral.f5.com/articles/configuring-apm-client-side-ntlm-authentication] to allow seamlessly authentication for domain-joined machines:
  • Do I need to replace on the 'Negotiate' branch the AD box for an NTLM box [NTLM Auth Result]?
  • A not domain-joined machine will follow basic or negotiate branch?
  • on the HTTP 401 box, What do I need to select on 'HTTP Auth Level' [none, basic, negotiate, basic+negotiate]?
Many thanks
1 REPLY 1
Stanislas_Piro2
Cumulonimbus
Cumulonimbus
NTLM is not configurable in APM yet.
To support NTLM auth, you have to
  • enable eca profile in the virtual server configuration (tmsh only, not available in webui)
  • create a NTLM profile in APM
  • enable this profile with an irule
  • create a NTLM auth result box in APM to get NTLM auth status done before APM evaluation.
