sukru_isik_8872's avatar
sukru_isik_8872
Aug 05, 2013
no space left on device
I have a f5 3900 and I have a disk problem.when I want to take a ucs file,I see an error like that:
"can't write temp config file "bigip.conf",in temp dir "/.config.tmp/xI06TM",No space left on device "
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg--db--sda-set.1.root
287M 287M 0 100% /
/dev/mapper/vg--db--sda-set.1._config
3.0G 86M 2.8G 3% /config
/dev/mapper/vg--db--sda-set.1._usr2.0G 1.5G 401M 80% /usr
/dev/mapper/vg--db--sda-set.1._var
3.0G 352M 2.5G 13% /var
/dev/mapper/vg--db--sda-dat.share.1
30G 196M 28G 1% /shared
/dev/mapper/vg--db--sda-dat.log.1
6.9G 367M 6.2G 6% /var/log
none 4.0G 708K 4.0G 1% /dev/shm
none 4.0G 16M 3.9G 1% /var/tmstat
none 4.0G 1.3M 4.0G 1% /var/run
prompt 4.0M 28K 4.0M 1% /var/prompt
/dev/mapper/vg--db--sda-app.ASWADB.set.1.mysqldb12G 2.9G 8.4G 26% /var/lib/mysql
none 4.0G 8.0K 4.0G 1% /var/logd
/dev/mapper/vg--db--sda-app.avr.dat.avrdata
3.8G 65M 3.5G 2% /shared/avr
what can I do about that?is there anyone experinces this issue?
  • /dev/mapper/vg--db--sda-set.1.root
    287M 287M 0 100% /what eats up space on root (/)?
  • shaggy's avatar
    shaggy
    SOL14403: Maintaining disk space on the BIG-IP system (11.x) http://support.f5.com/kb/en-us/solutions/public/14000/400/sol14403.html
    SOL12263: Maintaining disk space on the BIG-IP system (9.x - 10.x) http://support.f5.com/kb/en-us/solutions/public/12000/200/sol12263.html
    I have run into issues in the past with admins using their /home/ folders, which are in the root partitions, for file storage instead of in the /shared/ partition.
  • Sil's avatar
    Sil
    I run into the same question: what eats up space on root?
    Why there are only 427M total space for / ex works? Actually we have 58M free space, only 14%. Is this critical? What to do? We dont stored any datas on the f5, no tcpdumps, no stuff in home directories and so on.
    Is 58M free space enough for the f5 to work in a stable and performant way? Or do we have to adjust the partition structure?
    I hope someone can help :-)
    Update: we solved it, it was our fault - we monitor our f5's with ansible and did not set the parameter keep_remote_files=false
  • Hi,
    When I have faced such issue, I have removed unwanted files with .gz and .tar extensions in /var folder.
    Also I have removed all files in /tmp folder.
    Usually BIGIP images also occupies more space. It is recommened to remove unwanted bigip image files.
    Thanks,
    Rohitha
