sairudra_121197's avatar
sairudra_121197
Jan 07, 2014
No connection to third parties when connecting to F5 VPN edge client
I am having VPN on Edge Gateway 8900 with HF 6, version 11x
I have about 5k plus users connecting to the VPN. We are using Full tunneling.
Everything was working fine until last week, where some group of Marketing users started complaining about not connecting to internet (external websites like gmail.com or yahoo.com) when connected to the F5 Big IP edge client adapter (which is installed on their systems).
Its not the problem with the adapter as i tried to uninstall and re-install it.
Most of my Marketing guys are on the fields and they work on MIFI wireless cards from Verizon.
They are able to connect to the internet when they are not connected to VPN using the MIFI wireless card. However, when they connect to VPN using F5 edge client adapter. Then the third party websites does not show up.
Please someone help me with this issue and give me some steps that i should follow or look into.
Truly appreciated!!!
  • BinaryCanary_19's avatar
    BinaryCanary_19
    Historic F5 Account
    Does the BIGIP to which their traffic is tunneled still have access to the Internet?
    • Adegboyega_2561's avatar
      Adegboyega_2561
      Hi FKnuckles, did you help find a solution to Siarudra's issue? I'm having a similar problem and was hoping to learn something from that experience.
