need to create a log for the VIP usage
newbie
Altostratus
Altostratus
Is there a way for creating a log that shows a specific VIP has not been used for the last few days?
Thanks.
3 REPLIES 3
PeteWhite
F5 Employee
F5 Employee
yes - use an iCall to run daily and check/reset the VS stats
Known_Guy
Or you can also save the page in pdf format for the VIP statistics and compare.
Gajji
Cirrus
Cirrus
clear the Statistics of VIP and check afer few days to see if any traffic in there
