17-Nov-2022 10:19
Hi - we are trying to send duplicate ingress syslog UDP/514 traffic to two pools. We see that is not supported by using clone pools. Is there a way to do that? iRule? log publisher? I have looked on DevCentral and there is a lot of messages but no clear solutuons. Thanks -Steve
17-Nov-2022 11:04
Hi @steve_michaels ,
I recommend to try to configure Log destinations and Log publishers.
Follow the below Article From F5 :
https://techdocs.f5.com/en-us/bigip-14-1-0/big-ip-access-policy-manager-secure-web-gateway-14-1-0/lo...
Hope it helps you.
If I reach out for an iRule for youe environment , I will definitely share it in this thread !
Regards
17-Nov-2022 11:21
OK thanks @Mohamed_Ahmed_Kansoh . We are running BigIP v15.1.5.1 LTM. I will take a look at the link you sent.
17-Nov-2022 11:48
@steve_michaels ,
Try to use " clone pool option " under advanced configuration of your virtual server.
Check below :
> Article to know about this option " clone pool option "
https://www.kareemccie.com/2020/03/what-are-different-types-of-pools-in-f5.html
> F5 KB to configure this option :
https://support.f5.com/csp/article/K13392
I think , there are not iRules to kill loadbalancing and send send Traffic to multiple pools at the same time.
I think you can achieve this idea by " clone Pool option "
Try it and give me your feedback , I hope it success with you
Regards
