vrivoire_97090's avatar
vrivoire_97090
Oct 29, 2008
Solved
MS Print servers
Hi all,
I am planning to use my new F5 LTM to load balance Windows Server 2003 print servers. For the moment, it doesn't work for me: I can see the shared printer but I can't map it.
Has anayone already "played" with LTM & MS print servers ?
Thanks,
Vincent
  • Here's the new link to the guide for creating the WMI monitor. As I recall it was pretty straightforward. I'm even using the same interval and timeout. Looking at my monitor properties, the only thing I see that is different is my alias service port is 3389 and the external program path is /usr/bin/monitors. Also, you'll need to enable remote WMI requests on the win2k8 boxes if not already enabled.
    Monitoring WMI Services from Big-IP
