flomkrl_29950
Feb 04, 2008mq series feedback ?
Hello,
I will maybe have to load balance mq series servers.
On F5 site i got a short explanation of configuration : https://support.f5.com/kb/en-us/solutions/public/5000/900/sol5994.html?sr=414070
Load balancing IBM WebSphere MQ, also known as MQSeries, on the BIG-IP LTM does not require a special configuration. After configuring a standard TCP virtual server, which is usually configured on port 1414, you can direct the TCP virtual server to a pool of resource servers configured for the same service.
Have you other recommandation ?
I have visited some mq series sites (http://www.mqseries.net) which talk about load balancing issue like timeout or monitoring.
What is the best monitoring check to do (tcp,snmp,wmi, ...)? Is there any tcp string sample ?
Which timeout has to be configured ?
Is there any persistence methode better than source ip ?
Does Performance L4 is sufficient ?
Thanks for your experience feedback;
Best Regards,
Flo
