14-Feb-2020 00:16
Hello,
I need help to set up a specific ldap monitor
this is a post in which I have to pass parameters provided by the server administrator
When I curl, it works
When I put it in a monitor the answer is KO
curl
curl --location --request POST 'http://@IP/wsLdapWEB/services/LdapWsService' \
--header 'Content-Type: application/xml' \
--header 'SOAPAction:foo' \
--data '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ejb="http://ejb.ws.ldap.com">
<soapenv:Header/>
<soapenv:Body>
<ejb:login>
<ejb:in0>my-login</ejb:in0>
<ejb:in1>my-password</ejb:in1>
</ejb:login>
</soapenv:Body>
</soapenv:Envelope>'
Reply
<?xml version="1.0" encoding="UTF-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><loginResponse xmlns="http://ejb.ws.ldap.com"><loginReturn>12C5E7F-F2D6-F00579A61C</loginReturn></loginResponse></soapenv:Body></soapenv:Envelope>
In the monitor configuration I put this :
send string
POST http://10.29.56.48/wsLdapWEB/services/LdapWsService HTTP/1.1\r\n Content-Type: text/xml;charset=UTF-8rnHost: wsauth.carrefour.com\r\nSOAPAction:foo\"\"\r\n\r\nn<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" xmlns:ejb=\"http://ejb.ws.ldap.com\"><soapenv:Header/><soapenv:Body><ejb:login><ejb:in0>my-login</ejb:in0><ejb:in1>my-password</ejb:in1></ejb:login></soapenv:Body></soapenv:Envelope>\r\n
receive string
loginreturn
when I assign this monitor to the pool, the server is seen down
thank you in advance for your help
Cedric.
14-Feb-2020 00:45
Hi
1 - can you try POST /wsLdap..etc, and Host:10.29.56.48
2- can you enable "Monitor Logging" on a pool member, and provide the correpsonding log file in /var/log/monitors/
This may also help for details.
https://devcentral.f5.com/s/articles/ltm-http-monitoring-with-post-request
Let me know if it helps.
Yoann
