Kevin_Hickman_1's avatar
Kevin_Hickman_1
Aug 08, 2005
Mixed case compares ?
What is the best syntax to compare uri's in a mixed case environment.
I want to use something along the lines of:
if (http_uri starts_with "/cccard/public/en/ApplyNow")
redirect to "https:/%h/%u"
Where the A in apply and N in now could be either upper or lower case.
Thanks.
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    Kphi,
    What distribution of the 4.x code are you running on your BigIP? The practices for this vary slightly depending on which release you're on.
    Thanks,
    -Colin
    Colin_Walker_12
    Historic F5 Account
    Kphi,
    To do this in the 4.6.1 and later branch, you'd use the "tolower" command, which we made available as of 4.6.1.
    We have a solution about it on askf5.com here:
    Click here http://tech.f5.com/home/bigip/solutions/lb/sol2796.html
    Basically, the syntax looks like this:
    rule WhateverCase {
      if (tolower(http_uri) ends_with "jpg") {
        use pool web
        use pool web1
    Whenever performing a string comparison while using the tolower command, it will treat everything as lowercase, so you should be set.
    Hope this helps,
    -Colin
