Mirroring between two vCMP guests
forsan_102218
I have questions regarding mirroring. Is it possible to get mirroring working between...
1) two vCMP guests running on the same blade?
2) two vCMP guests running on two different blades in one chassi?
Best Regards
Andréas
2 REPLIES 2
Stephan_Mierau
F5 Employee
F5 Employee
what do you mean with mirroring? If you want to build a cluster between two vCMP Guest, yes this is possible, on the same blade and on different blades.
just my 2 cent,
Stephan
amolari
Cirrus
Cirrus
vCMP guest HA (DSC clustering) is not supported in the same chassis.
http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/vcmp-administration-viprion-11-5-...
"two guests must reside on separate chassis"
Alex
