Rasool1224's avatar
Rasool1224
Jan 29, 2019
Microservice Protection
Hi, Please anyone can advice me about the Microservice Protection in ASM, i have 14.1.
thank you
  • Microservice is no different than normal service from the network point of view - if the microservice you want to protect is already configured as a virtual server on your F5 ASM you can create an ASM policy to protect it.
    • Ireda's avatar
      Ireda
      Thanks to provide me with more details
      Are microservices separated from ASM policy or it is the entity from it? when can I use the microservices? also, it must need a specific VS for it!
