access2AE_25064's avatar
access2AE_25064
Jul 18, 2016
Management / KeyCertificate -How to get Certificate Signature Algorithm
Hi ,
Currently in our organization we are doing SHA1 migration. I have been trying to get Certificate Signature Algorithm(PKCS 1 SHA-1 With RSA Encryption) from the Management::KeyCertificate get_certificate_list method;apparently it provides only Subject Public Key Algorithm(PKCS 1 RSA Encryption).
Is there any way i can get Certificate Signature Algorithm as well??
Many thanks in advance!
Regards- Prabir
  • JG's avatar
    JG
    The following bash script will show which SSL certificate in the /Common partition contains a sha1 Signature Algorithm:
    for i in /config/filestore/files_d/Common_d/certificate_d/*; do
        echo "$i:"; openssl x509 -text -noout -in $i |grep 'Signature Algorithm' | grep sha1
    done
  • JG's avatar
    JG
    Well, you can do this with iControlREST.
    Create a bash script named, say, "check_insecure_sig_algo.sh", with the following code:
    !/bin/sh
        if openssl x509 -text -noout -in $i | /bin/grep 'Signature Algorithm: sha1' 2>&1 > /dev/null
        then
                echo $i
        fi
    done
    and then run the following remotely:
    !/bin/sh
    OUTPUT="$(curl -k -s -u admin:admin -H "Content-Type: application/json" -X POST https://mgmt_IP_address/mgmt/tm/util/bash -d "{\"command\":\"run\",\"utilCmdArgs\":\"-c '/path/to/check_insecure_sig_algo.sh'\"}" | jq '.commandResult')"
    insecure_certs="${OUTPUT%\"}"
    insecure_certs="${insecure_certs\"}"
    echo "$insecure_certs"
    to get a list of the certs with sha1 signature algorithm. You need to download and install jq, though.
