Technical Forum
Malformed XML data
SCRN
Altostratus
Altostratus
Hi all,  have xml request like below
ASM was detect this request as XML parser attack (Malformed XML data). In policy XML profile is Default
When delete all <value> and <field>, request is ok
BI
It's by desing with default XML profile? is there a solution that would allow the request to be resolved given with this  <value> and  <field>. Thx
1 REPLY 1
AubreyKingF5
Community Manager
Community Manager
Do you not have the ability to learn this? Also, best practice is to never use a default profile if you need to use it. Also.. do you have a WSDL for the app? When creating a new XML profile, you can upload a WSDL to teach your ASM what unique values your app might have.
