IT's avatar
IT
Aug 22, 2019
Maintenance page won't show
Hello,
I have an issue while setting an irule to show a maintenance page, here is the irule:
  if { [active_members [LB::server pool]] < 0 } {
  HTTP::respond 503 content [ifile get "Maintenance"]}
I think the problem is coming from the multiple irules in my VS, I have 20 differents pools included in different irules.
The irule above is working where I have only 1 pool which is set by default and 1 irule.
The test I made is to disable 1 pool in one of my irules to show this "Maintenance" page but it didn't work, which is expected because the pool I disable was not the default pool.
So how do I make a global irule to show my maintenance page when any of my pool included in my irules is down ? Or do I have to modify every irules with pool redirection ?
Thank you.
ps: I have bigIP 14.1.0.2.
  • Snl's avatar
    Snl
    try using priority in IRULE to execute this irule before rest of the Irules
    when HTTP_REQUEST priority  10 {
    • IT's avatar
      IT
      I try this and nothing change.
  • Hi Oodrive IT,
    You must change number to 1.
    if { [active_members [LB::server pool]] < 1 }
    • IT's avatar
      IT
      Hello,
      It was copy/paste mistake because I tried :
      if { [active_members [LB::server pool]] == 0 }
      I set :
      didn't work
