Sort By
- Andy_McGrathCumulonimbus
Any MAC address that is not on any of the F5 connected networks.
Best to take a MAC off the F5 and change the first hex pair to 02 to avoid any conflicts.
e.g. 00:01:d7:93:35:08 to 02:01:d7:93:35:08
- eesun_276598Cirrus
thanks for your reply. right. I guess making change to 02 of the first hex could make it absolutely unique address. Can you tell why?
First half of the MAC is vendor hardware, 02 is reserved so never hard set by a vendor so should make it unique.
thank you
So we can say that changing any one of the first half part should make the mac unique, right?
No as you might conflict with another vendors MAC, though unlikely it is possible.
