Technical Forum
ltm ending session
Abed_AL-R_26070
hello
Is there any option in ltm to delete a session from persistence table after it recognized a pattern in url ?
I mean , right now we've configured persistent with source addr + 10 minutes max for each session . But sometimes users end there session after two minutes and we dont need that session to be anymore in the persistent table . So we have a URL with specific pattern which means that that user has ended his session . So is there anyway to configure the f5 ltm machine to delete a session from persistence table after it recognized that pattern in the URL ?
1 REPLY 1
JG
Cumulonimbus
Cumulonimbus
Try an irule like the following:
when HTTP_REQUEST { if { [HTTP:path] equals '/remove_persistence' } { persist delete source_addr [IP::client_addr] } }
