Technical Forum
Custom Alert Banner
LTM and GTM on the same box on both site then use GTM sync
Justine_313324
Altostratus
Altostratus
Hi everyone! I would like to ask if using a single box on both GTM and LTM. My design is I have two F5 appliances with 2 modules(GTM and LTM) that will be located on each DMZ site(2 DMZ sites). I would like to use GTM for global load balancing and LTM for the local load balancing of the app/web servers. Since I have two appliances, I would like to GTM sync the two appliances.
Question: Is this possible?
Thanks!
9 REPLIES 9
eben
Hi Justine,
Yes it is.
Regards
Eben.
Would it not introduce some errors? What are the keynotes for this?
eben
No it will not. keynotes: 1. ensure capacity planning is done right per the model you have. 2. config is same as when you have GTM AND LTM on separate boxes. you need to do bigip_add for the other GTM/LTM and when you are done with configuring the first GTM you can sync its config from the second GTM. gtm_add . this cmd should be from the second unconfigured GTM.
HTH Eben.
Thanks Eben.
eben_259100
Hi Justine,
Yes it is.
Regards
Eben.
HTH Eben.
Thanks a lot .. I just need to make sure if it will need to have extra license like Vcmp or no need ?
Thanks Eben.
