Technical Forum
localdbmgr DOWN
THE_BLUE
The /var partion is almost full and i access through cli and i noticed that localdbmgr DOWN config # , what is this? and how to fix it ? and does this service may cause the /var is almost full ? because i faced /var issue in one appliance only where the localdbmgr DOWN .
where in the second appliance the /var is good and i have not seen this localdbmgr DOWN  in cli.
3 REPLIES 3
PeteWhite
F5 Employee
F5 Employee
localdbmgr controls the APM local database - see https://my.f5.com/manage/s/article/K61101414
My guess is that ths is because the disk is full. Clear the disk, do a restart, hopefully it'll be fine. If not, raise a case or look at bugs related to localdbmgr
Thank you for your response.
actully i have 2 applaince and both with the same resources , size and so on. the issue of var is in one appliance where the localdbmgr is down . so my indication was , this service might cause /var to be full .
is it save to restart localdbmgr ?
Thanks for the link, I appreciate it.
I was searching for an official website online where I can find reviews for an online essay writing service and when I was searching for it online, I found your post and it is quite much interesting and that is why I took an interest in your post.
