14-Jan-2022 02:12
Dears,
Kindly I need to the following:-
Thank you in advance
26-Jan-2022 01:46
If you have the DNS module then the link monitoring is the way:
https://support.f5.com/csp/article/K6848
If not then maybe you can test with a transperant monitor and check a specific destination by going through the two ISP:
https://support.f5.com/csp/article/K8971
Also if one ISP should be active and the other standby check the F5 priority group option:
