Eric_Waite_1046's avatar
Eric_Waite_1046
Oct 06, 2006
jsessionid uri vs. cookie
I am using the following rule to persist via jsessionId.
when CLIENT_ACCEPTED {
set add_persist 1
when HTTP_RESPONSE {
if { [HTTP::cookie exists "JID"] and $add_persist } {
persist add uie [HTTP::cookie "JID"]
set add_persist 0
if { [HTTP::cookie exists "JID"] } {
persist uie [HTTP::cookie "JID"]
set jsess [findstr [HTTP::uri] "jsessionid" 11 "?"]
if { $jsess != "" } {
persist uie $jsess
But my application passes sessionId in the URI with every request so the following should work, with no response.
persist uie $jsess
This works, if the browser set to block cookies. If it allows cookies the persistence fails? Does BIG-IP look for the cookie, if cookies are enables? Or Am I missing something here. I would love to eliminate cookies 100 percent and just pull from the URI.
Any help would be appreciated.
Eric
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    There's no reason that this rule:
        persist uie $jsess
    would be looking for cookies. Is that the version you're using?
    Colin
  • unRuleY_95363's avatar
    unRuleY_95363
    Historic F5 Account
    In order for jsessionid persistence to work, you need to find the jsessionid in the first response and add a persistence record for it. The only challenge to not using cookies is looking/parsing for the persist key in the first responses body from the server. Cookies are easy since they are headers and we have commands to access them directly. You will need to collect the response and parse it for the jsessionid, so you can add the initial key to the table.
    • Mohamed_Lrhazi's avatar
      Mohamed_Lrhazi
      Yes! No one seems to mention this key fact... even this solution document... erroneously suggests you dont need to find the actually session ID in the first response: http://support.f5.com/kb/en-us/solutions/public/7000/300/sol7392.html
