whootang's avatar
whootang
Mar 22, 2015
Issue with URI rewrite
Hi Guys,
Having some issues on a rewrite rule I'm trying to create (sorry first time looking at these)
I am trying to copy a rule we have in apache at the moment.
RewriteCond %{HTTP_HOST} ^support.yourdomain.com$ [NC]
RewriteRule ^/(.*)$ https://support.3rdpartywebsite.com/$1 [P,L]
So when our users enter support.yourdomain.com it goes off to support.3rdpartywebsite.com I am assuming and want the end user to not know that support.3rdpartywebsite.com URL and hit it direct.
This is what I have so far but it dosent seem to work any tips?
if { [HTTP::uri] equals "support.yourdomain.com" } { HTTP::uri "https://support.3rdpartywebsite.com" } }
Thanks R
  • So when our users enter support.yourdomain.com it goes off to support.3rdpartywebsite.com I am assuming and want the end user to not know that support.3rdpartywebsite.com URL and hit it direct.
    if you just want to change http host header in request only, you can use HTTP::header replace command but if support.3rdpartywebsite.com is also embedded in response body (so, you have to rewrite it back to support.yourdomain.com), you may need to use proxypass which Mark suggested.
    e.g.
     config
    root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 172.28.24.10:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 19
    root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
    ltm pool foo {
        members {
            200.200.200.101:80 {
                address 200.200.200.101
    root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
    ltm rule qux {
      if { [HTTP::host] eq "support.yourdomain.com" } {
        HTTP::header replace Host "support.3rdpartywebsite.com"
     trace
    [root@ve11c:Active:In Sync] config  ssldump -Aed -nni 0.0 port 80
    New TCP connection 1: 172.28.24.1(53863) <-> 172.28.24.10(80)
    1427071308.3080 (0.0279)  C>S
    GET /someting HTTP/1.1
    User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
    Accept: */*
    Host: support.yourdomain.com
    New TCP connection 2: 200.200.200.14(53863) <-> 200.200.200.101(80)
    1427071308.3122 (0.0030)  C>S
    Accept: */*
    Host: support.3rdpartywebsite.com
