juan_salinas_47
Jul 09, 2010Nimbostratus
issue with global variable in a simple irule
hi,
first of all, excuse my english.
i've implemented this simple irule:
when RULE_INIT {
set test 1
when CACHE_REQUEST timing on {
set httppath [string tolower [HTTP::path]]
log local0. "mycache $httppath"
if { $httppath ends_with ".jpg" } {
set TTL 240
elseif { $httppath ends_with ".swf" } {
set TTL 660
else {
este valor debe ser menor o igual que el maximum age de el profile de cache
set TTL 3610
if { [CACHE::age] > $TTL } {
CACHE::expire
if { $TTL == 3610 } {
log "mycache ttl $TTL expired $httppath "
the issue appears when i uncomment the line "set test 1" in the RULE_INIT event. I get a lot of this messages in ltm logs
Jul 9 15:09:36 local/ASM1 err mcpd[4473]: 01020066:3: The requested rule (cachesetup) already exists in partition Common.
Jul 9 15:10:28 local/tmm warning tmm[5951]: 011e0002:4: sweeper_update: aggressive mode activated. (376549/442880 pages)
Jul 9 15:10:47 local/tmm warning tmm[5951]: 011e0001:4: Limiting open port RST response from 251 to 250 packets/sec
Jul 9 15:11:36 local/tmm1 warning tmm1[5952]: 011e0002:4: sweeper_update: aggressive mode activated. (376732/442880 pages)
Jul 9 15:11:44 local/tmm1 notice tmm1[5952]: 01010029:5: Clock advanced by 171 ticks
Jul 9 15:11:44 local/tmm1 warning tmm1[5952]: 011e0002:4: sweeper_update: aggressive mode deactivated. (361861/442880 pages)
Jul 9 15:11:51 local/tmm1 warning tmm1[5952]: 011e0002:4: sweeper_update: aggressive mode activated. (379372/442880 pages)
Jul 9 15:16:14 local/ASM1 err bcm56xxd[4498]: 012c0010:3: Failover event detected. Marking external interfaces down. bsx.c(3276)
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.1 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.2 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.3 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.4 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.5 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.6 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.7 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.11 is DOWN
Jul 9 15:16:15 local/ASM1 info bcm56xxd[4498]: 012c0015:6: Link: 1.12 is DOWN
Jul 9 15:16:25 local/ASM1 info bcm56xxd[4498]: 012c0012:6: Connected to failover service.
when i disable the line "set test 1" the messages stop and the vserver and pool back to UP state.
the LTM software version is 10.2.0.1707.0
any ideas about this?
thanks
