06-Mar-2019 04:51
we have below requirement for load Balancing of ISO 8583 traffic,
ISO messages require special handling to determine the start and end of the messages. A message will have its first two bytes as header. In this two bytes the length of the message body will be mentioned. Hence when a load-balancer port starts listening, it has to read the first two bytes. Get the contents of these two bytes in HEX, convert it to decimal to get the length of the message body. Read till the end of the message, depending on the message length. Route the message(both header and body) to a destination internal application Server and continue listening. Please find below example,
Example of a complete ISO message including header and body bytes: [1,56,48, 50, 48, 48, 70, 50, 49, 67, 54, 52, 56, 49, 48, 56, 69, 49, 48, 48, 48, 56, 48, 48, 48, 48, 48, 48, 48, 48, 48, 54, 48, 48, 48, 49, 48, 48, 49, 54, 52, 54, 53, 53, 55, 51, 49, 55, 50, 52, 49, 57, 53, 53, 52, 55, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 53, 49, 48, 48, 48, 48, 48, 49, 50, 49, 48, 48, 50, 51, 56, 51, 54, 49, 54, 51, 55, 51, 52, 49, 50, 51, 48, 50, 49, 49, 50, 54, 48, 49, 49, 48, 53, 54, 48, 56, 49, 49, 48, 48, 54, 54, 50, 50, 48, 49, 56, 56, 57, 49, 50, 51, 52, 53, 54, 55, 56, 57, 49, 57, 57, 57, 56, 49, 50, 51, 52, 49, 49, 49, 49, 57, 57, 48, 56, 56, 57, 57, 48, 56, 56, 57, 84, 69, 82, 77, 73, 78, 65, 76, 79, 87, 78, 69, 82, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 67, 104, 101, 110, 110, 97, 105, 32, 32, 32, 32, 32, 32, 84, 78, 73, 78, 48, 49, 49, 48, 53, 49, 48, 48, 53, 65, 84, 77, 48, 49, 48, 50, 49, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 55, 49, 49, 49, 48, 50, 49, 57, 55, 56, 53, 53, 48, 52, 54, 49, 57, 55, 49, 50, 48, 51, 54, 52, 52, 51, 52, 49, 57, 51, 49, 54, 57, 56, 56, 55, 51, 51, 51, 56, 55, 50, 57, 55, 49, 51, 54, 50, 48, 51, 56, 48, 48, 49, 48, 48, 50, 52, 53, 48, 48, 50, 48, 48, 51, 77, 79, 66, 48, 52, 53, 48, 48, 52, 65, 66, 67, 68, 48, 53, 49, 48, 48, 53, 65, 84, 77, 48, 49]
First two bytes (header): [1, 56]
First two bytes in HEX: 0138
First two bytes in decimal: 312
Message body length: 312
Bytes to be sent to destination Application port : 2+312 = 314
Please help with I-rule and LTM configuration.
06-Mar-2019 07:33
Can anyone please update ?
06-Mar-2019 20:55
Any help on this
06-Mar-2019
23:22
- last edited on
01-Jun-2023
16:11
by
JimmyPackets
You can read irule 2 in this article
It’s an example on how to manage message based load balancing with binary decoding.
To convert binary to 2 bytes integer, use command
binary scan $payload S msg_len
The S converts 2 bytes to 16bitd signed integer!
10-Mar-2019
10:51
- last edited on
21-Nov-2022
21:35
by
JimmyPackets
You can try this code:
when CLIENT_ACCEPTED {
prevent first packet to be released to server before CLIENT DATA inspected (CLIENT_DATA Event)
TCP::collect
when CLIENT_DATA {
if {[binary scan [TCP::payload] S length] == 1 && [expr { ($length & 0xffff) +2 }] == [TCP::payload length]} {
log local0. "This packet length meets header length value : Header value : [expr { ($length & 0xffff) }] / Packet Length : [TCP::payload length]"
release packet to server... the data length equals the data header length value.
TCP::release
Allow to load balance per packet
TCP::notify request
prevent next packet to be released to server before CLIENT DATA inspected (loop on CLIENT_DATA Event)
TCP::collect
Packet length doesn't meet Header length value... this is not a valid ISO 8583 packet.
log local0. "This packet length doesn't meet header length value... this is not a valid ISO 8583 packet. reject the connection"
reject
when USER_REQUEST {
We don't expect a response, so let's just signal one
and detach to make oneconnect happy (message-based)
TCP::notify response
LB::detach
This code supports oneconnect profile assigned to the virtual server and load balance to server message-based and not connection-based.
26-Oct-2022 11:57
We tried this iRule on a virtual server with the oneconnect profile but it didn't work.
Does anyone have a working iRule and setup to load balance ISO8583 transactions that are received through a single tcp connection on the virtual server?
