Ladarfar's avatar
Ladarfar
Feb 17, 2020
Is it possible to use DIGEST authentication on health monitor
Currently my health monitor settings are:
Send string:  GET /URI HTTP/1.1\r\nHost:example.com\r\nConnection: Close\r\n\r\n
Get string: HTTP/1.1 200 OK
I also have user and password.
Problem is that i get response 401 unauthorized. I also checked that username and password are correct.
Server only supports Digest authentication sample response:
< HTTP/1.1 401 Unauthorized
< WWW-Authenticate: Digest
  • I don't believe that is built in. You may need to create an external monitor and use a script that runs a curl command like this:
    curl --digest --user daniel:secret http://example.com/
