capsuleNimbostratusMar 03, 2020IRULES decode base 64 header authorizationDear, I want to know if there is an irule to decode a base64 authorization code header on a http authentication basic request ? regards,
1 ReplyReplies sorted by Most LikedSort ByMost LikedOldestNewesttiziano_rosatoCirrusMar 03, 2020this should hellp:https://clouddocs.f5.com/api/irules/b64decode.html
Recent DiscussionsF5Access | MacOS SonomaActive- Active HA setupsyslog server connectionCannot see floating MAC address outside of ESXiRewrite uri translation not working
Related ContentDecoding the IPv4 address from the persistence cookieiRule - Authorization Bearer / BasicResolve Citrix Secure Ticket Authority (STA)Base32 Encoding and Decoding With iRulesASM irule to disable attack signature authorization header with specific value
