mbrunyak1's avatar
mbrunyak1
Jun 24, 2022
Solved
iRule
I have the below http iRule. Moving url to https and need to convert iRule for https use.
if {[HTTP::header X-Forwarded-For] != ""} then {
persist uie [lindex [ split [lindex [HTTP::header values X-Forwarded-For] 0] "," ] 0]
persist uie [IP::client_addr]
  • Hi,
    Did you test the irule in the new HTTPS URL? basically, the irule persists the IP using the x-forwarder-for header or the client_addr in the case the X-forwarder-for is not present, and this keep as HTTP no HTTPS because is a header in the packet, so this irule works without any modification.
    • mbrunyak1's avatar
      mbrunyak1
      Thank you. Yes I did test and it wasn't working. I thought maybe I had to modify for HTTPS
