Technical Forum
Custom Alert Banner
Irule to use different persistence cookie by node
impala_38421
I need to create an irule that use different pools according the URL requested and insert a different persistence cookie to each pool member
I will try to explain the scenario.
The elements are:
One Virtual Server: VS1
Three Pools: Pool1, Pool2, Pool3
Two Nodes: Node1, Node2
6 persistence cookies: ck1, ck2, ck3, ck4, ck5, ck6
3 URLs that could be used by source user. VS1 has the IP of the URL, and the URL allways is the same only changes the resource
htttps://URL/XXXX
htttps://URL/YYYY
htttps://URL/ZZZZ
The work policy must be the next:
request to:
https://URL/XXXX
    Pool1
       Node1 with persistence ck1
       Node2 with Persistence ck2
https://URL/YYYY
    Pool2
       Node1 with persistence ck3
       Node2 with Persistence ck4
https://URL/ZZZZ
    Pool3
       Node1 with persistence ck5
       Node2 with Persistence ck6
To try to do it I have created the next Irule
    switch [HTTP::host] {
        https://URL/XXXX {
        Pool1
        https://URL/YYYY {
            Pool2
        https://URL/ZZZZ {
        Pool3
        default { reject }
Now I need to insert the cookie to each node. Please could you help finish this configurtion?
Thaks in advance.
Jordi
4 REPLIES 4
nitass
F5 Employee
F5 Employee
doesn't default cookie persistence work since pool name is included in cookie name?
K6917: Overview of BIG-IP persistence cookie encoding
https://support.f5.com/csp/article/K6917
by the way, i think the switch should look like this.
switch -glob [HTTP::host][HTTP::uri] {
    "URL/XXXX*" {
        pool Pool1
Hi nitass,
Thanks for your answer and sorry for my delay.
I want review you suggestion and trying to configure the irule as follow
    "https://xxx.xxx.com/xxxxx" {
        pool Pool1
    "https://xxx.xxx.com/yyyyy" {
        pool Pool2
    "https://xxx.xxx.com/zzzzz" {
        pool Pool3
Now the original request has changed and I need insert http cookie for each pool.
This is an example:
        pool Pool1
        persist cookie insert <>
        pool Pool2
        pool Pool3
Do you think that is this the correct configuration?
Many Thanks,
Jordi
nitass_89166
Noctilucent
Noctilucent
    "URL/XXXX*" {
        pool Pool1
Hi nitass,
        pool Pool1
        pool Pool2
        pool Pool3
This is an example:
        pool Pool1
        pool Pool2
        pool Pool3
Many Thanks,
Jordi
