Mark_Gallagher's avatar
Mark_Gallagher
Nov 01, 2019
iRule to protect a URI pattern by subnet?
Good day,
I have been trying several approaches on BIG-IP/LTM 12.1.3.7 to achieve the following goal:
A VIP listens on an IP where most of the traffic is bound for web content, let's say https://something.company.com/content/blahblahblah. anything that does not start with /manage basically.
Some admins will come from internal RFC 1918 source IPs and should be allowed to access https://something.company.com/admin/blablabla
Any other requests not from this broad RFC 1918 subnet for /admin should be dropped/rejected/redirected to a sorry page or so.
I seems like it should be simple to do this via an iRule like so:
  set httpUri [string tolower [HTTP::uri]]
  set clientIp [class match -value [IP::client_addr] equals datagroup_allowed_ip_www_manage]
  if { $httpUri starts_with "/admin" && $clientIp equals "" } {
    drop
    pool prd-pl-company
The datagroup includes some rfc-1918 addresses like so:
ltm data-group internal /Common/datagroup_allowed_ip_www_manage {
    records {
        192.168.0.0/16 { }
    type ip
The above approach does not work. Non /manage requests will fall through to the VIP and anything with /manage will be dropped regardless of source IP.
I've tried this with a a line in the irule to specify the subnet using /16 or 192.168.0.0/255.255.0.0 rather than the datagroup but it doesn't work either.
I've tried with a policy like so:
ltm policy /Common/pol-admin-isolate {
    controls { forwarding }
    description "policy admin network isloate"
    last-modified 2019-10-28:05:45:55
    requires { http tcp }
    rules {
        prd-pol-admin-isolate-allow-internal-cli-net {
            actions {
                0 {
                    forward
                    select
                    pool /Common/prd-pl-company
            conditions {
                0 {
                    tcp
                    address
                    case-sensitive
                    matches
                    values { 193.168.0.0/16 }
                1 {
                    http-uri
                    path
                    normalized
                    starts-with
                    values { /admin }
        prd-pol-www-manage-isolate {
            actions {
                0 {
                    forward
                    reset
            conditions {
                0 {
                    http-uri
                    path
                    normalized
                    starts-with
                    values { admin }
            ordinal 1
    strategy /Common/first-match
This works exactly like the iRule.
I must be overlooking something, but I cannot figure out what it might be. Anyone have any luck doing something similar?
Thanks,
Mark
  • JG's avatar
    JG
    Try the following:
        if { ([string tolower [HTTP::uri]] starts_with "/admin") && not ([IP::addr [IP::client_addr] equals 192.168.0.0/16]) } {
            drop
            pool prd-pl-company
    • Thanks for the input JG. I did try this (also with an exclamation point outside the parentheses) and it doesn't seem to match. I have definitely been able to get the match to work with a large list of /32 addresses, but never the /16.
      This what I tried as far as what they were recommending in a KB for efficient subnet matching:
       if {( [string tolower  [HTTP::uri]] contains "/admin") && (not[IP::addr [IP::remote_addr] equals 192.168.0.0/255.255.0.0])} {
              HTTP::respond 503 content {
