Technical Forum
Custom Alert Banner
iRule Recommendation
chocokoala
Altostratus
Altostratus
I need help for an irule to be used for this scenario (this is a outlook/owa/autodiscover setup)
we currently have a setup/irule that if the client type webmail.abc.com/owa it goes to the owa pool, if webmail.abc.com/autodiscover it goes to autodiscover pool
my question now, they want to change the domain that if the user types webmail.abc.com it redirect to webmail.xyz.com, if user type webmail.abc.com/owa redirect to webmail.xyz.com/owa same with /autodiscover
we used the iapp for exchange setup btw,, for this redirection is there a way we can do this? or is this simple redirection irule that redirect webmail.abc.com to webmail.xyz.com ?
3 REPLIES 3
A simple redirection irule should do the redirection :
  if { [HTTP::host] eq "webmail.abc.com" } {
    HTTP::redirect "https://webmail.xyz.com[HTTP::uri]"
 Then you old irule should take care of pool selection :
  if { [HTTP::uri] starts_with "/owa" } {
    pool OWA_pool
  elseif { [HTTP::uri] starts_with "/example" } {
    pool Example_pool
If irules are associated to the same VS, yous should make sure the redirect execute first, you have a number of options for that including checking for the hostname before pool selection, or adding priorities to your events
will try this, thanks!
Hi again,
For the 2nd line:
don't i need to add [HTTP::uri] ?
sorry im just newbie on f5 irules
