Technical Forum
Custom Alert Banner
iRule Help on Logging the cookie parameter's value.
viziony
Cirrus
Cirrus
Hello There --
Would like to get your assistance on logging from an iRule. I would like the irule to log to the LTM logs to see if the connection is sending over the cookie parameter's value
if { [HTTP::header "Route-to-AB”] equals "YES" }{
    pool pool-A
    // log local0.info ?
    pool pool-B
The same above, I want to make sure I using "Log local0.info" correctly. If additional information is required for the logging to work? I just want to see if the header includes the parameter "Route-to-AB" with a value.
1 REPLY 1
Kai_Wilke
MVP
MVP
Hi viziony,
check out the modified iRule below...
	if { [HTTP::header value "Route-to-AB"] equals "YES" } then {
		pool pool-A
		log local0.info "Header \"Route-to-AB\" value is \"YES\"."
		pool pool-B
		log local0.info "Header \"Route-to-AB\" value is \"[HTTP::header value "Route-to-AB"]\"."
Note: You may change the log-level "info" to "debug" if subsequent messages getting supressed. LTM has a filter for non debug messages.
Cheers, Kai
iRule can do… 😉
