25-Apr-2013 07:59
Hi, I need an iRule for transparent redirect, basically I have VIP in legacy floor which needs to send partial traiffic to another VIP for example application 1 while they are migration all applications to new servers..
will below irule works? is this transparent to Clinets? I am going to aplly below iRule on legacy VIP.
switch -glob [string tolower [HTTP::uri] ] {
"/app/*" {
HTTP::redirect “https://www.example.com[HTTP::uri]”
“/app2*” {
HTTP::redirect “https:://www.example .com[HTTP::uri]”
Please help.
thx
25-Apr-2013 09:40
25-Apr-2013 18:24
if same, you may try "virtual" command.
virtual wiki
https://devcentral.f5.com/wiki/irules.virtual.ashx
if different, you may try "node" command.
node wiki
https://devcentral.f5.com/wiki/iRules.node.ashx
29-Apr-2013 07:53
another VIP is The VIP on different F5 in SAT envirornmnet. Can you tell me what is going to be actual iRule?
will this work?
"/app/*" {
HTTP::uri “https://www.example.com[HTTP::uri]”
“/app2*” {
HTTP::uri “https:://www.example .com[HTTP::uri]”
thx
