Sort By
- Mario_Apitz___uNimbostratusHello!
- hooleylistCirrostratusHi Mario,
- Thomas_SchaeferNimbostratusOne thing that makes this a hard issue is that your parser in the iRule needs to understand something of the SQL statement. For example, if you simply send the SELECTS to one pool and the UPDATE, INSERT and DELETE to another pool, you also have to handle UPDATE . Not a very common construct, but still to be handled. I hate to say it but setting up an MYSQL cluster might be a more robust solution.
- Mario_Apitz___uNimbostratusHi Aaron, hi Tom,
