Technical Forum
iRule for SameSite Strict attribute
Vishnu2212
Hi Folks,
I need iRule for setting the samesite = strict attribute and call it in virtual server. I have tried available article but it is not working. SameSite is reflecting as None from the browser developer tool.
Here is my iRule.
when HTTP_RESPONSE_RELEASE {
set samesite_security "strict"
set cookie_names [HTTP::cookie names]
foreach a_cookie $cookie_names {
# Remove any prior instances of SameSite attributes
HTTP::cookie attribute $a_cookie remove {samesite}
# Insert a new SameSite attribute
HTTP::cookie attribute $a_cookie insert {samesite} $samesite_security
if {$cookie_debug}{log local0. "[IP::client_addr]:[TCP::client_port]: Set-Cookie header values: [HTTP::header values {Set-Cookie}]"}
1 REPLY 1
Have you checked this article as it mentons a bug:
https://support.f5.com/csp/article/K14225515
Also search the bugtracker for bugs for samesite :
https://support.f5.com/csp/bug-tracker?sf189923893=1
