14-Apr-2020 09:39
Hey all,
I've been racking my brain trying to get a domain host replacement for a wildcard domain.
Trying to do anything:
*.domain1.com to redirect to *.domain2.com with the URI. Can't seem to do the replacement of the domain/hostname.. Any suggestions? I thought it would be simple, but proving not so much.
14-Apr-2020 15:25
Are you trying to simply rewrite the domain of the host-header on an inbound request before it gets sent to a pool member?
15-Apr-2020 05:23
Yep, want it to completely redirect to the other domain.
16-Apr-2020 06:58
Hello,
Please try below iRule,
if { [HTTP::host] equals "domain1.com"} {
HTTP::redirect "https://domain2.com[HTTP::uri]"
Also you can even try to achieve this using policy.
Hope it works !
Mayur
16-Apr-2020 07:50
Mayur, Thanks for that, but that just redirects a single domain1.com to domain2.com -- I need all the wildcard virtual domains to redirect too.. for instance site1.domain1.com to site1.domain2.com -- trying to do it without individual redirects for every virtual domain (thousands)
16-Apr-2020 13:12
I have use this iRule in the past to get accomplish something similar
HTTP::host [string map {".old-domain.com" ".new-domain.com"} [HTTP::host]]
HTTP::respond 307 Location https://[HTTP::host][HTTP::uri]
It should do a wild card replacement like you want, or at least similar functionality
