Technical Forum
iRule exclude URI
Alex_Pintel
I am fairly new to iRules so any help greately appreciated.
What is correct syntax to exclude URI "/abc/Web123/cde/forum123/ from receiving HTTP code 200 and the message "123456789"? Is the exclamation mark a orrect synatx to exclude URI?
Here is iRule
set http_path [ string tolower [HTTP::path]]
if { ! ($http_path starts_with "/abc/Web123/cde/forum123") } {
HTTP::respond 200 content "
<html>
<head>
<title></title>
</head>
<body>
123456789
</body>
</html>
Thank you for any assistamce you can provide.
1 ACCEPTED SOLUTION
To negate starts_with I would use the not operator:
https://clouddocs.f5.com/api/irules/not.html
  if { not ([HTTP::uri] starts_with "/abc") } {
     # do something ...
     # do something else...
For excluding the exact path, you can go with  the "ne" operator
6 REPLIES 6
mihaic
MVP
MVP
As far as i know you can use ! or NOT.
Here are the operators list:
https://clouddocs.f5.com/api/irules/Operators.html
Hi @Alex_Pintel ,
Could you please try this :
#set http_path [ string tolower [HTTP::path]]
if { [HTTP::path] ne "/abc/Web123/cde/forum123" } {
<html>
<head>
<title></title>
</head>
<body>
123456789
</body>
</html>
I tested it on my lab and it works well.
Regards
_______________________
Regards
Mohamed Kansoh
CA_Valli
MVP
MVP
Hello, if you're looking to exclude an exact match for a string, "ne" operator can be used as well.
One thing I noticed -- since this is an exact match, be careful with "string tolower" syntax as it will convert everything to lowercase, so you will never see Web123 -- it's gonna be web123 instead.
I generally don't recommend converting paths to lowercase since it is case sensitive, try using this instead:
if { [HTTP::path] ne "/abc/Web123/cde/forum123" }{ ... }
Thank you all for responding to my post. I have another question.
What would be right syntax if I need to use 2 URLs?
if { [HTTP::path] ne "/abc/Web123/cde/forum123" OR "/abc/Web123/cde/forum456"
Is the "OR" correct operator?
Thank you!
For the requested logic, you need the "and" operator between two tests:
if { ([HTTP::path] ne "/abc/Web123/cde/forum123") and ([HTTP::path] ne "/abc/Web123/cde/forum456") }
 If you plan to add more paths in the future, then consider using a switch test
     # do something ...
