Technical Forum
Custom Alert Banner
iRule datagroup sideband
fraandres
I been trying to use HSSR to use a curl to add an IP to a datagroup, here is my code but still can't figure out what I"m missing
the curl works if I use this, but Need to use it on a iRule any help will be appreciated
curl -ku "admin:admin" -X PATCH -H 'Content-type: application/json' -d '{ "name":"active_visitor_ips" }' https://localhost/mgmt/tm/ltm/data-group/internal/active_visitor_ips?options=records%20add%20%7b%201... |jq .
Edit: I got the debugs.
<ACCESS_POLICY_COMPLETED>: {/data-group/internal/active_visitor_ips?options=records%20add%20%7b%2010.125.135.5%20%7b%20data%20IP%20%7d%20%7d}
<ACCESS_POLICY_COMPLETED>: HSSR 10.125.94.10:58173: http_req arguments must be '-option value' pairs
01220001:3: TCL error: /Common/session_test <ACCESS_POLICY_COMPLETED> - http_req arguments must be '-option value' pairs (iRule proc "/Common/HSSR::http_req") (line 1) invoked from within "call /Common/HSSR::http_req -uri "https://localhost/"-method -X PATCH -H -type -userid admin -passwd admin application/json -body $jsonBody -rbody"
when ACCESS_POLICY_COMPLETED {
set clientip [ACCESS::session data get "session.user.clientip"]
set jsonBody "{curl -ku \"admin:admin\" \'Content-type: application/json\' -d \'{ \"name\":\"active_visitor_ips\" }\' /data-group/internal/active_visitor_ips?options=records%20add%20%7b%20$clientip%20%7b%20data%20IP%20%7d%20%7d |jq .}"
log local0. $jsonBody
#set jsonBody "{curl -ku \"admin:admin\" \'Content-type: application/json\' -d \'{ \"name\":\"active_visitor_ips\" }\'}"
#set jsonBody "{ \"shared-secret\":\"$checkpoint_api_secret\", \"ip-address\":\"$clientip\", \"user\":\"$api_username\" , \"session-timeout\":$timeout }"
set send_info [call /Common/HSSR::http_req -uri "https://localhost/"-method -X PATCH -H -body $jsonBody -rbody]
#log local0. $apiResp
if{[IP::$clientip equals active_visitor_ips]}{
HTTP::redirect "https://captive-portal.com"
when ACCESS_SESSION_CLOSED {
# run sideband http PATCH request to remove this clientip from active_visitor_ips datagroup
#set send_info [send PATCH "/mgmt/tm/ltm/datagroup/internal/active_visitor_ips\?options=delete$data"]
2 REPLIES 2
Leslie_Hubertus
Community Manager
Community Manager
Debugging an iRule? @Kai_Wilke may be able to help with that, if @JRahm or the community don't jump in with an answer first!
JRahm
Community Manager
Community Manager
Hi @fraandres, you might reformat your question to put all code and debug info in code blocks so it's easier to read.  If I'm following correctly, in using the HSSR, you should just need to pass the details of your request, it will not be able to do anyting with curl:
call /Common/HSSR::http_req \
-uri "http://localhost/mgmt/tm/ltm/data-group/internal/active_visitor_ips?options=records%20add%20%7b%2010.125.135.5%20%7b%20data%20IP%20%7d%20%7d" \
-method PATCH \
-rbody
