Technical Forum
Custom Alert Banner
iRule assistance for subfolder redirect
captaincroc
Hi All,
iRule newbie here. I have a URL "https://blog.example.com/oldsubfolder/FBAR" that I would like redirected to "https://blog.example.com/newsubfolder/FBAR".
I tried using the below iRule but it doesn't preserve whats appended after the subfolder. Any assistance would be greatly appreciated.
if { !([HTTP::host] starts_with "https://blog.example.com/oldsubfolder/") } {
HTTP::redirect "https://[HTTP::host]/newsubfolder/"
1 ACCEPTED SOLUTION
CA_Valli
MVP
MVP
Hello,
in this attempt I'm using the getfield command to split URI by "/oldsubfolder/" string, so that first "oldsubfolder" match would be field 1 and the rest of your URI will be field 2.
I'm replacing /oldsubfoler/ with new path manually and then appending the rest of your uri using field 2 syntax.
 if { [HTTP::uri] contains "/oldsubfolder/"} {
   HTTP::redirect https://[HTTP::host]/newsubfolder/[getfield [HTTP::path] "/oldsubfolder/" 2]
I haven't had the chance to test this in a lab, please do before installing.
1 REPLY 1
CA_Valli
MVP
MVP
Hello,
