irule 404 page
craig_lee10_177
Hi
I am wondering if someone can point me in the right direction. Basically the below works fine when I try and go to a directory that doesn’t exists
when HTTP_RESPONSE {
if { [HTTP::status] == 404 } {
HTTP::respond 200 content [ifile get "index"]
The issue I have is that the file index is an html file which references images etc which don’t get displayed the when the page is severed. I have tried using ifles to resolve this but I think my syntax is wrong; could someone give me a suggestion on what I need to do?
Craig
6 REPLIES 6
What_Lies_Bene1
This post should give you almost everything you need: https://devcentral.f5.com/community/group/aft/2165545/asg/50
However, you'll need to add some logic to ensure requests you don't want handled by this are just passed along. I'd suggest you add some unique path for the images in the index.html file that the 'normal' application would never use, for example: /404/404/image1.jpg. Then you can just do an if [HTTP::uri]] starts_with "/404/404" in a HTTP_REQUEST event; if it matches, you'll serve the iFile, if not things just work as normal.
What_Lies_Bene1
A quick example;
when HTTP_REQUEST { if { [HTTP::uri] starts_with "/404/404" } { switch -glob [string tolower[HTTP::uri]] { "*/favicon.ico" { HTTP::respond 200 content [ifile get favicon_ico] } "*/reset.css" { HTTP::respond 200 content [ifile get reset_css] } } } }
craig_lee10_177
that makes sense now, ill give that a go and let you know what happens, many thanks Steve for your time.
Craig
What_Lies_Bene1
You're welcome. Post back if you need to.
nitass
F5 Employee
F5 Employee
e.g.
[root@ve11a:Active:Changes Pending] config tmsh root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.20.14:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } rules { myrule } source 0.0.0.0/0 source-address-translation { type automap } vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } } } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule ltm rule myrule { when HTTP_RESPONSE { if { [HTTP::status] == 404 } { HTTP::respond 200 content [ifile get maint_html_ifile] noserver "Content-Type" "text/html" } } when HTTP_REQUEST { switch [HTTP::uri] { "/f5.gif" { HTTP::respond 200 content [ifile get f5_gif_ifile] noserver "Content-Type" "image/gif" } } } } original response from pool [root@ve11a:Active:Changes Pending] config curl -I http://200.200.200.101/something HTTP/1.1 404 Not Found Date: Sat, 19 Jan 2013 06:50:00 GMT Server: Apache/2.2.3 (CentOS) Content-Type: text/html; charset=iso-8859-1 rewritten response from bigip [root@ve11a:Active:Changes Pending] config curl -i http://172.28.20.14/something HTTP/1.0 200 OK Content-Type: text/html Connection: Keep-Alive Content-Length: 97 This is maintenance page. [root@ve11a:Active:Changes Pending] config curl -I http://172.28.20.14/f5.gif HTTP/1.0 200 OK Content-Type: image/gif Connection: Keep-Alive Content-Length: 3994
craig_lee10_177
Thanks for your help guys this is what I used in the end
log local0. "\HTTP::host\]\[HTTP::uri\]: [string tolower [HTTP::host]][string tolower [HTTP::uri]]"
switch -glob [string tolower [HTTP::uri]] {
"*404/404/css/baselogin.css" {HTTP::respond 200 content [ifile get baselogin] "Content-Type" "text/css"}
"*404/404/images/icon_alert.gif" {HTTP::respond 200 content [ifile get icon_alert] "Content-Type" "image/gif"}
"*404/404/images/logo_percep_sm.gif" {HTTP::respond 200 content [ifile get percep_sm] "Content-Type" "image/gif"}
"*404/404/images/bkg_loginbody.gif" {HTTP::respond 200 content [ifile get bkg_loginbody]"Content-Type" "image/gif" }
"*404/404/images/bkg_loginbottom.gif" {HTTP::respond 200 content [ifile get bkg_loginbottom]"Content-Type" "image/gif" }
"*404/404/images/bkg_logintop.gif" {HTTP::respond 200 content [ifile get bkg_logintop]"Content-Type" "image/gif" }
"*404/404/images/bkg_logintop.gif" {HTTP::respond 200 content [ifile get bkg_splashbody]"Content-Type" "image/gif" }
HTTP::respond 200 content [ifile get "main_index"] noserver "Content-Type" "text/html" }
